Api session event editor geotiff set geotiff
API Endpoint: api/session/event/editorgeotiff/set_geotiff/
Description: Update existing GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL.
0 REQUIRED (GEO_TIFF Integer ID) GeoTIFF ID
1 REQUIRED (byte or multiple values in array [a, b, c]) File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 OPTIONAL (String) CRS Override (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Uploader" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], "Uploader" ]'
JavaScript example POST:
 body: '[ 1, 1, "Uploader" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff/", options)
