Api session event editor area generate inundation areas
API Endpoint: api/session/event/editorarea/generate_inundation_areas/
Description: Generate Inundation Areas
0 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '28'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '85'
JavaScript example POST:
 body: '28'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/", options)
