Api session event editor area generate border areas
API Endpoint: api/session/event/editorarea/generate_border_areas/
Description: Generate Border Areas
0 REQUIRED (String) String
1 REQUIRED (String) String
2 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 95 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 40 ]'
JavaScript example POST:
 body: '[ "Text", "Text", 95 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/", options)
