Api session event editor address set point
API Endpoint: api/session/event/editoraddress/set_point/
Description: Set the Point of an Address
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address ID
1 REQUIRED (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658715.7630794083, 6799344.425169232 ]
Curl example multi item POST:
[ [ 1, 2, 3 ], [ {
 "type" : "Point",
 "coordinates" : [ 658751.0133291892, 6799361.471872229 ]
 "type" : "Point",
 "coordinates" : [ 658769.5479702922, 6799362.3375260765 ]
 "type" : "Point",
 "coordinates" : [ 658659.1262055436, 6799362.67696635 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658715.7630794083, 6799344.425169232 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
