Api session items parametricdesigns
Api Session Items Parametric Designs Endpoint: /api/session/items/parametricdesigns/
Edit items with events described at Api session event editor parametric.
Default Query:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=JSON&token=API_TOKENExample Response:
[ ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/parametricdesigns/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/parametricdesigns/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/parametricdesigns/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPSMILE&token=API_TOKENApi Model Alignment
API Enumeration description of Alignment
| Name | Description |
| ROAD | |
| SPACED |
Api Model GeometryCollection
API Model description of GeometryCollection
| Name | Type | Description |
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model ParametricDesign
API Model description of ParametricDesign
| alignment | Alignment | |
| attributes | Map<String,double[]> | |
| center | Point | |
| gardenID | int | Function ID |
| id | int | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| parkingID | int | Function ID |
| plotDesigns | PlotDesign[] | |
| polygons | MultiPolygon | |
| publicGreenID | int | Function ID |
| roadID | int | Function ID |
| sidewalkID | int | Function ID |
| sourceIDs | int[] | Sources ID |
| version | int | |
| waterID | int | Terrain Type ID |
Api Model PlotDesign
API Model description of PlotDesign
| functionID | int | Function ID |
| id | int | |
| multiPolygon | MultiPolygon |
Api Model Point
API Model description of Point
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
