Api session event participant net cluster set states
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/net_cluster_set_states/
Description: Set Timestate for all Net Loads of Net Cluster.
0 REQUIRED (STAKEHOLDER Integer ID) Initiating Stakeholder ID
1 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
2 REQUIRED (NetType or multiple values in array [a, b, c]) Net Type Array
3 REQUIRED (TimeState or multiple values in array [a, b, c]) Timestate Array (NOTHING, Request_CONSTRUCTION_APPROVAL, Request_ZONING_APPROVAL, READY)
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "ELECTRICITY", "NOTHING" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ "ELECTRICITY", "GAS", "HEAT" ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ] ]'
JavaScript example POST:
 body: '[ 1, 1, "ELECTRICITY", "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/", options)
