Api session event logic measurement line add
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/measurement_line_add/
Description: Add a LineMeasurement for an Overlay for a specific Timeframe.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs
1 REQUIRED (Point with crs: EPSG:3857) Point start
2 REQUIRED (Point with crs: EPSG:3857) Point end
3 REQUIRED (String) Name
4 REQUIRED (Integer number) Timeframe (-1 for automatic last)
5 REQUIRED (true, false) Save Measurement true or false
6 REQUIRED (true, false) Sum true or false
200 Integer (Measurement ID)
curl 'https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658719.2630926905, 6799322.782274678 ]
 "type" : "Point",
 "coordinates" : [ 658798.7954130701, 6799315.42181975 ]
}, "Name", -1, true, true ]
Curl example multi item POST:
[ [ 1, 2, 3 ], {
 "type" : "Point",
 "coordinates" : [ 658689.8581087114, 6799445.903604035 ]
 "type" : "Point",
 "coordinates" : [ 658707.0918168032, 6799332.859872217 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658719.2630926905, 6799322.782274678 ]}, { "type" : "Point", "coordinates" : [ 658798.7954130701, 6799315.42181975 ]}, "Name", -1, true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857", options)
