Api session event editor panel export debug excel
API Endpoint: api/session/event/editorpanel/export_debug_excel/
Description: Export Debug Excel Sheet
| 0 | REQUIRED | (PANEL Integer ID) | Panels |
| 200 | byte[] (byte array) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/export_debug_excel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/export_debug_excel/", options)
