Api session event editor indicator set excel
Revision as of 14:45, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorindicator/set_excel/
Description: Set Excel Sheet
0 REQUIRED (INDICATOR Integer ID) Indicators
1 REQUIRED (EXCEL_SHEET Integer ID) Excel Sheets
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_excel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_excel/", options)
