Api session event editor global set book value
Revision as of 14:45, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorglobal/set_book_value/
Description: Set Book Value
0 REQUIRED (GLOBAL Integer ID) Globals
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_book_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_book_value/", options)
