Api session event editor excelsheet export
API Endpoint: api/session/event/editorexcelsheet/export/
Description: Export
| 0 | REQUIRED | (EXCEL_SHEET Integer ID) | Excel Sheets |
| 200 | byte[] (byte array) |
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/export/", options)
