Api session event editor area generate inundation areas
API Endpoint: api/session/event/editorarea/generate_inundation_areas/
Description: Generate Inundation Areas
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '77'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '88'JavaScript example POST:
body: '77'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/", options)
