Api session event editor area generate border areas
API Endpoint: api/session/event/editorarea/generate_border_areas/
Description: Generate Border Areas
| 0 | REQUIRED | (String) | String | |
| 1 | REQUIRED | (String) | String | |
| 2 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 91 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 52 ]'JavaScript example POST:
body: '[ "Text", "Text", 91 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/", options)
