Api session event logic special effect set active
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/special_effect_set_active/ Description: Activate/deactivate a Special Effect. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(SPECIAL_EFFECT Integer ID) |Special Effect ID | |- |1 |REQUIRED |(true, false) |Activated |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Curl example POST:...")
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect ID
1 REQUIRED (true, false) Activated true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/special_effect_set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/special_effect_set_active/", options)
