How to add and remove an Area
Revision as of 13:55, 29 May 2026 by Frank@tygron.nl (talk | contribs)
Editor → Current Situation (Ribbon tab) → Areas (Ribbon bar)
How to add an Area to the project:
  1. Select Current situation in the ribbon header.
  2. Select Areas in the ribbon bar.
  3. Select 'Add' at the bottom of the left panel.
  4. Notice that the new Area has been added to the list of Areas.
How to remove an Area from the project:
  3. Select the Area that should be removed in the left panel.
  4. Select 'Remove' at the bottom of the left panel.
  5. Notice that the Area has been removed from the list of Areas.
