Api session items netlines
Api session items Net Lines Endpoint: /api/session/items/netlines/
Edit items with event: editornetline.
Default Query:
https://engine.tygron.com/api/session/items/netlines/?f=JSON&token=API_TOKENExample Response:
"attributes" : null,
"endNodeID" : 1,
"functionID" : 0,
"id" : 0,
"maquetteOverride" : null,
"name" : "NetLine 0",
"sourceIDs" : [ ],
"startNodeID" : 0,
"version" : 31
"endNodeID" : 58,
"functionID" : 0,
"id" : 1,
"name" : "NetLine 1",
"sourceIDs" : [ ],
"startNodeID" : 35,
"version" : 32
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/netlines/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/netlines/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/netlines/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/netlines/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/netlines/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netlines/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/net_lines-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/netlines/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/netlines/size/?token=API_TOKENNet Lines (GeoJSON):
https://engine.tygron.com/web/lines.geojson?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/netlines/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/netlines/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/netlines/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/netlines/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/netlines/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/netlines/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/netlines/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/netlines/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/netlines/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/netlines/?f=ZIPSMILE&token=API_TOKENApi Model NetLine
API Model description of NetLine
| Name | Type | Description |
| attributes | Map<String,double[]> | |
| endNodeID | int | Net Node ID |
| functionID | int | Net Function ID |
| id | int | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| sourceIDs | int[] | Source ID |
| startNodeID | int | Net Node ID |
| version | int |
