Api session event editor specialeffect set location
Revision as of 08:21, 29 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorspecialeffect/set_location/
Description: Set Location
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658777.7628506548, 6799403.318951813 ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658703.8094377576, 6799332.296305995 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658777.7628506548, 6799403.318951813 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857", options)
