Api session event editor netload generate loads and paths
API Endpoint: api/session/event/editornetload/generate_loads_and_paths/
Description: Generate Loads And Paths
0 REQUIRED (NET_FUNCTION Integer ID) Net Function
1 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
2 REQUIRED (Category or multiple values in array [a, b, c]) Category[]
3 REQUIRED (Integer number) Integer
4 REQUIRED (Integer number) Integer
5 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Stakeholder
6 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Stakeholder
7 REQUIRED (true, false) Boolean true or false
8 REQUIRED (Floating point number) Double
9 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_loads_and_paths/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "SOCIAL", 1, 1, 1, 1, true, 14, 54 ]
Curl example multi item POST:
[ 1, {
}, [ "SOCIAL", "NORMAL", "LUXE" ], 1, 1, [ 1, 2, 3 ], [ 1, 2, 3 ], true, 26, 2 ]
JavaScript example POST:
 body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, "SOCIAL", 1, 1, 1, 1, true, 14, 54 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_loads_and_paths/?crs=3857", options)
