Api session event editor netline insert point
API Endpoint: api/session/event/editornetline/insert_point/
Description: Insert a new Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
| 0 | REQUIRED | (NET_LINE Integer ID) | Net Line ID | |
| 1 | REQUIRED | (Point 3D with crs: EPSG:3857) | Inserted Node Point | |
| 2 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658714.8795493732, 6799372.057866874, -0.05 ]
'Curl example multi item POST:
[ 1, {
"type" : "Point",
"coordinates" : [ 658680.5453123493, 6799364.0460964115, -0.71 ]
'JavaScript example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658714.8795493732, 6799372.057866874, -0.05 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857", options)
