Api session event editor address set point
Revision as of 08:19, 29 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoraddress/set_point/
Description: Set the point of an Address
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address ID
1 REQUIRED (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658657.6108865681, 6799428.2265610155 ]
Curl example multi item POST:
[ [ 1, 2, 3 ], [ {
 "type" : "Point",
 "coordinates" : [ 658664.0099827779, 6799371.661582077 ]
 "type" : "Point",
 "coordinates" : [ 658770.5451898538, 6799429.178300867 ]
 "type" : "Point",
 "coordinates" : [ 658691.5731964265, 6799448.5395721365 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658657.6108865681, 6799428.2265610155 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
