Api session event editor area add
Revision as of 11:25, 19 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/add/
Description: Add new Area
0 OPTIONAL (Integer number) Amount (optional)
200 Integer[] (Area IDs)
curl 'https://engine.tygron.com/api/session/event/editorarea/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST:
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorarea/add/", options)
