Api session event editor address set point
API Endpoint: api/session/event/editoraddress/set_point/
Description: Set the point of an Address
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address ID
1 REQUIRED (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658721.9656551507, 6799386.861716602 ]
Curl example multi item POST:
[ [ 1, 2, 3 ], [ {
 "type" : "Point",
 "coordinates" : [ 658677.6364846051, 6799422.111716371 ]
 "type" : "Point",
 "coordinates" : [ 658702.6563011309, 6799381.125323125 ]
 "type" : "Point",
 "coordinates" : [ 658644.5171013795, 6799396.1646872545 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658721.9656551507, 6799386.861716602 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
