Api session event editor weather set effect
API Endpoint: api/session/event/editorweather/set_effect/
Description: Set what kind of Weather the specified Weather is.
| 0 | REQUIRED | (WEATHER Integer ID) | Weather ID | |
| 1 | REQUIRED | (Enumeration) | Weather Type Effect | DROUGHT, FLOODING, NO_EFFECT, RAIN, SNOW or WIND |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorweather/set_effect/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "NO_EFFECT" ]'JavaScript example POST:
body: '[ 1, "NO_EFFECT" ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_effect/", options)
