Api session event editor specialeffect set location
API Endpoint: api/session/event/editorspecialeffect/set_location/
Description: Set Location
| 0 | REQUIRED | (SPECIAL_EFFECT Integer ID) | Special Effect | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658679.1989035275, 6799416.290843314 ]
'Curl example multi item POST:
[ 1, {
"type" : "Point",
"coordinates" : [ 658771.673964439, 6799398.698319385 ]
'JavaScript example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658679.1989035275, 6799416.290843314 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857", options)
