Api session event editor parametric add
Revision as of 08:17, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorparametric/add/
Description: Add new Parametric
0 REQUIRED (Enumeration) Alignment ROAD or SPACED
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorparametric/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ROAD"'
JavaScript example POST:
 body: '"ROAD"'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add/", options)
