Api session event editor panel set url
API Endpoint: api/session/event/editorpanel/set_url/
Description: Set Url
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (String) | String |
| 200 | String (String) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript example POST:
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_url/", options)
