Api session event editor panel set template attribute
Revision as of 08:17, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/set_template_attribute/
Description: Set Template Attribute
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (String) String
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'
JavaScript example POST:
 body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_attribute/", options)
