Api session event editor panel set size
Revision as of 08:17, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/set_size/
Description: Set Size
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 9, 90 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 15, 61 ]'
JavaScript example POST:
 body: '[ 1, 9, 90 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_size/", options)
