Api session event editor panel apply template panels
Revision as of 08:17, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/apply_template_panels/
Description: Apply Template Panel
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Panel
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/apply_template_panels/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/apply_template_panels/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/apply_template_panels/", options)
