Api session event editor netload set state
API Endpoint: api/session/event/editornetload/set_state/
Description: Set State
| 0 | REQUIRED | (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) | Net Load | |
| 1 | REQUIRED | (TimeState or multiple values in array [a, b, c]) | TimeState[] |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "NOTHING" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ] ]'JavaScript example POST:
body: '[ 1, "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_state/", options)
