Api session event editor netload set point
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/set_point/
Description: Set Point
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 OPTIONAL (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "" ]'
JavaScript example POST:
 body: '[ 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_point/?crs=3857", options)
