Api session event editor netload set node
API Endpoint: api/session/event/editornetload/set_node/
Description: Set Node
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Load | |
| 1 | REQUIRED | (NET_NODE Integer ID) | Net Node |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/set_node/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_node/", options)
