Api session event editor netline set net function
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetline/set_net_function/
Description: Set the Net Function for a Net Line
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Net Line
1 REQUIRED (NET_FUNCTION Integer ID or multiple values in array [1, 2, 3]) Net Function
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetline/set_net_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetline/set_net_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/set_net_function/", options)
