Api session event editor netline remove repeated
Revision as of 08:16, 15 May 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetline/remove_repeated/
Description: Remove the Net Line, and optionally continue removing for Net Node that are connected the removed Net Line and that are only connected to one other Net Line of the same Net Type of the specified Net Line.
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Net Line IDs
1 REQUIRED (true, false) Is repeated removal true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_repeated/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_repeated/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], true ]'
JavaScript example POST:
 body: '[ 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/remove_repeated/", options)
