Api session event editor netline insert point
API Endpoint: api/session/event/editornetline/insert_point/
Description: Insert a new Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
| 0 | REQUIRED | (NET_LINE Integer ID) | Net Line ID | |
| 1 | REQUIRED | (Point 3D with crs: EPSG:3857) | Inserted Node Point | |
| 2 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658712.8185206702, 6799388.739200741, -1.45 ]
}, 1.0 ]
'Curl example multi item POST:
[ 1, {
"type" : "Point",
"coordinates" : [ 658647.138457035, 6799366.829832503, -1.61 ]
}, 1.0 ]
'JavaScript example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658712.8185206702, 6799388.739200741, -1.45 ]}, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857", options)
