Api session event editor indicator set stakeholder
API Endpoint: api/session/event/editorindicator/set_stakeholder/
Description: Set Stakeholder
| 0 | REQUIRED | (INDICATOR Integer ID) | Indicator | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_stakeholder/", options)
