Api session event editor geotiff add
API Endpoint: api/session/event/editorgeotiff/add/
Description: Add new GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL.
| 0 | REQUIRED | (String) | GeoTIFF Name | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | File bytes (< 2GB) | |
| 2 | REQUIRED | (String) | Uploader | |
| 3 | OPTIONAL | (String) | CRS Override (optional) |
| 200 | Integer (GeoTIFF ID) |
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", 1, "Uploader", "" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "" ]'JavaScript example POST:
body: '[ "GeoTIFF Name", 1, "Uploader", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add/", options)
