Api session event editor area add relation
API Endpoint: api/session/event/editorarea/add_relation/
Description: Add Relation
| 0 | REQUIRED | (AREA Integer ID) | Area | |
| 1 | REQUIRED | (Enumeration) | Relation | BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/add_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OWNER" ]'JavaScript example POST:
body: '[ 1, "OWNER" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_relation/", options)
