Api session event editor area add
API Endpoint: api/session/event/editorarea/add/
Description: Add new Area
| 0 | OPTIONAL | (Integer number) | Amount (optional) |
| 200 | Integer[] (Area IDs) |
curl 'https://engine.tygron.com/api/session/event/editorarea/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorarea/add/", options)
