Api session event editor address set point
API Endpoint: api/session/event/editoraddress/set_point/
Description: Set the point of an Address
| 0 | REQUIRED | (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) | Address ID | |
| 1 | REQUIRED | (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658794.0837942619, 6799317.042678403 ]
'Curl example multi item POST:
[ [ 1, 2, 3 ], [ {
"type" : "Point",
"coordinates" : [ 658707.2915855427, 6799348.547167871 ]
"type" : "Point",
"coordinates" : [ 658776.8452137618, 6799412.513124923 ]
"type" : "Point",
"coordinates" : [ 658691.9694856334, 6799438.3481413815 ]
'JavaScript example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658794.0837942619, 6799317.042678403 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
