Api session items overlays
Revision as of 12:43, 20 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Overlay Endpoints.
Edit items with event: editoroverlay.
Default Query:
https://engine.tygron.com/api/session/items/overlays/?f=JSON&token=API_TOKEN
Example Response:
  "attributes" : {
    "FOO" : [ 1.0 ],
    "PINO" : [ 87.824625 ],
    "SINGLE" : [ 75.624039 ],
    "SJAAKIE" : [ 97.724805 ]
  "colorMultiplier" : 1.0,
  "colorOffset" : 127,
  "customLegend" : false,
  "id" : 0,
  "imageName" : "normal.png",
  "imageVersion" : 0,
  "legend" : [ ],
  "maquetteOverride" : null,
  "name" : "namx8",
  "parentID" : -1,
  "sortIndex" : 52,
  "type" : null,
  "version" : 121,
  "visible" : true
  "attributes" : {
    "PINO" : [ 1.0 ],
    "SJAAKIE" : [ 1.0 ]
  "id" : 1,
  "imageName" : "neighborhoods.png",
  "imageVersion" : 0,
  "legend" : [ {
    "color" : {
      "argb" : -9772392
    "entryName" : "buurt",
    "id" : 1,
    "value" : "-Infinity"
    "color" : {
      "argb" : -1877165
    "entryName" : "Sonsbeek-Noord",
    "id" : 2,
    "color" : {
      "argb" : -16173383
    "entryName" : "Onder de Linden",
    "id" : 3,
    "color" : {
      "argb" : -6740311
    "entryName" : "St. Janskerkstraat e.o.",
    "id" : 4,
    "color" : {
      "argb" : -15232895
    "entryName" : "Hazegrietje",
    "id" : 5,
    "color" : {
      "argb" : -4609484
    "entryName" : "Klarenbeek",
    "id" : 6,
  "name" : "aOAcT",
  "parentID" : -1,
  "sortIndex" : 51,
  "type" : "NEIGHBORHOODS",
  "version" : 118,
  "visible" : true
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/overlays/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/overlays/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/overlays/size/?token=API_TOKEN
Overlays (GeoJSON):
https://engine.tygron.com/web/overlays.geojson?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/overlays/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/overlays/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/overlays/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/overlays/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/overlays/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/overlays/?f=ZIPSMILE&token=API_TOKEN
Api Model AeriusOverlay
API Model description of AeriusOverlay
Name Type Description
attributes Map<String,double[]>
colorMultiplier double
colorOffset int
customLegend boolean
id int
imageName String
imageVersion int
legend LegendEntry[]
maquetteOverride Map<String,double[]>
name String
parentID int Overlay ID
sortIndex int
type OverlayType
version int
visible boolean
Api Model AreaOverlay
API Model description of AreaOverlay
areaIDs int[] Area ID
colorOffset int
id int
imageName String
imageVersion int
name String
remainderColor TColor
sortIndex int
type OverlayType
version int
visible boolean
Api Model AttributeKey
API Enumeration description of AttributeKey
Name Description
A
B
C
D
E
F
G
H
I
J
Api Model AttributeOverlay
API Model description of AttributeOverlay
attribute String
attributeColor TColor
colorAttribute String
colorOffset int
id int
imageName String
imageVersion int
mapLink MapLink
name String
restColor TColor
sortIndex int
type OverlayType
version int
visible boolean
Api Model AttributeOverlayPredicate
API Model description of AttributeOverlayPredicate
attribute String
mapLink MapLink
Api Model AvgModelAttribute
API Enumeration description of AvgModelAttribute
Name Description
DISTANCE_M
ATTRIBUTE_TIMEFRAMES
DEFAULT_VALUE
SURFACE_ONLY
Api Model AvgOverlay
API Model description of AvgOverlay
active boolean
calcTimeMS long
colorOffset int
diffLegend LegendEntry[]
id int
imageName String
imageVersion int
inActiveCellSize double
inActiveTimeframes int
keys Map<String,String>
layerMapLink MapLink
maxValue float[]
minValue float[]
name String
prequels Map<String,PrequelLink>
rasterization Rasterization
resultType String
showDifference boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model BridgeElevation
API Enumeration description of BridgeElevation
Name Description
LOWEST
TERRAIN
BRIDGE
Api Model ClimateModel
API Model description of ClimateModel
endTemp double
endYear int
oxidation double
soilTempFactor double
startTemp double
startYear int
Api Model ComboModelAttribute
API Enumeration description of ComboModelAttribute
Name Description
ATTRIBUTE_DEFAULT_VALUE
ATTRIBUTE_SURFACE_ONLY
Api Model ComboOverlay
API Model description of ComboOverlay
active boolean
calcTimeMS long
colorOffset int
formula String
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model DefaultAttribute
API Enumeration description of DefaultAttribute
Name Description
ATTRIBUTE
Api Model DefaultOverlay
API Model description of DefaultOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model DefaultRasterizationOverlay
API Model description of DefaultRasterizationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model DefaultResult
API Enumeration description of DefaultResult
Name Description
DEFAULT
Api Model DischargeMethod
API Enumeration description of DischargeMethod
Name Description
HEIGHT_MINIMA
WATER_TERRAINS
AREAS
Api Model DistanceOverlay
API Model description of DistanceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model DistanceResult
API Enumeration description of DistanceResult
Name Description
ZONE
SIGHT
Api Model FloodingOverlay
API Model description of FloodingOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
weatherID int Weather ID
Api Model FunctionOverlay
API Model description of FunctionOverlay
colorOffset int
functionIDs int[] Function ID
functionsColor TColor
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model GasType
API Enumeration description of GasType
Name Description
NOX
NO2
Api Model GeoTiffAttribute
API Enumeration description of GeoTiffAttribute
Name Description
BAND
Api Model GeoTiffOverlay
API Model description of GeoTiffOverlay
active boolean
calcTimeMS long
colorOffset int
geoTiffIDs int[] GeoTIFF ID
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model GeoTiffResult
API Enumeration description of GeoTiffResult
Name Description
NEAREST
INTERPOLATED
Api Model GridModelAttribute
API Enumeration description of GridModelAttribute
Name Description
ITERATION_ACTIVE
SKIP_NO_DATA
GPU_CLUSTER_INDEX
Api Model GridOverlay
API Model description of GridOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model GroundwaterOverlay
API Model description of GroundwaterOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model HeatDpraAttribute
API Enumeration description of HeatDpraAttribute
Name Description
DATES
DAILY_AVG_RADIATION
DAILY_TEMPERATURE_MAX
DAILY_TEMPERATURE_MIN
EXCLUDE_BUILDINGS
EXCLUDE_WATER
EXCLUDE_FOLIAGE_HEIGHT_M
FOLIAGE_AREAS
HOURLY_RADIATION
HOURLY_TEMPERATURE
HOURLY_HUMIDITY
SUN_ALTITUDE
SUN_AZIMUTH
SUN_DAILY_MOTION
WIND_DIRECTION
WIND_SPEED
DAILY_AVG_WIND_SPEED
MAX_SHADOW_DISTANCE
MAX_TRUNK_DISTANCE
WIND_DECLINE_ANGLE
Api Model HeatKey
API Enumeration description of HeatKey
Name Description
FOLIAGE_HEIGHT
Api Model HeatModel
API Enumeration description of HeatModel
Name Description
UNESCO
DPRA
Api Model HeatOverlay
API Model description of HeatOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
model HeatModel
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model HeatPrequel
API Enumeration description of HeatPrequel
Name Description
FOLIAGE_HEIGHT
BUILDING_ELEVATION
TERRAIN_ELEVATION
Api Model HeatResult
API Enumeration description of HeatResult
Name Description
BOWEN_RATIO
FOLIAGE
PET
PET_RELATIVE
SHADE
SKY_VIEW
SKY_VIEW_AVG
TEMPERATURE_ATMOSPHERE
UHI
VEGETATION
VEGETATION_AVG
WIND_SPEED
Api Model HeightAttribute
API Enumeration description of HeightAttribute
Name Description
ZONING_PERMIT_REQUIRED
Api Model HeightOverlay
API Model description of HeightOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model HeightResult
API Enumeration description of HeightResult
Name Description
DSM
DTM
FLOORS
Api Model ImageAttribute
API Enumeration description of ImageAttribute
Name Description
ALPHA
Api Model ImageOverlay
API Model description of ImageOverlay
colorOffset int
id int
imageName String
imageNames String[]
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model InferenceAttribute
API Enumeration description of InferenceAttribute
Name Description
MASK_THRESHOLD
SCORE_THRESHOLD
INFERENCE_MODE
STRIDE_FRACTION
BOX_OVERLAP
PRIORITIZE_LABELS
GPU_MEMORY_MB
Api Model InferenceMode
API Enumeration description of InferenceMode
Name Description
CLASSIFICATION
BBOX_DETECTION
Api Model InferenceOverlay
API Model description of InferenceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
neuralNetworkID int Neural Network ID
resultType String
sortIndex int
tensorLinks TensorLink[]
type OverlayType
version int
visible boolean
warnings String
Api Model InferencePrequel
API Enumeration description of InferencePrequel
Name Description
A
B
C
Api Model InferenceResult
API Enumeration description of InferenceResult
Name Description
LABELS
SCORES
BOXES
MASKS
DEBUG_GT_INSTANCES
CENTER_POINTS
Api Model Input
API Enumeration description of Input
Name Description
A
B
C
D
E
F
G
H
I
J
Api Model IterationAttribute
API Enumeration description of IterationAttribute
Name Description
MODULUS
TIMEFRAME_TIMES
Api Model IterationOverlay
API Model description of IterationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model IterationPrequel
API Enumeration description of IterationPrequel
Name Description
ITERATION
Api Model MinMax
API Enumeration description of MinMax
Name Description
NEVER
LARGE_CELL
ALWAYS
Api Model Mode
API Enumeration description of Mode
Name Description
SPEED
AVERAGE
ACCURACY
Api Model NO2Overlay
API Model description of NO2Overlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model NO2Result
API Enumeration description of NO2Result
Name Description
CONCENTRATION
EMISSION_NO2
EMISSION_NOX
TREEFACTOR
TREES
Api Model NetOverlay
API Model description of NetOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
netType NetType
showActive boolean
showNetwork boolean
sortIndex int
type OverlayType
version int
visible boolean
Api Model NoPrequel
API Enumeration description of NoPrequel
Name Description
Api Model NoiseOverlay
API Model description of NoiseOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model NoiseResult
API Enumeration description of NoiseResult
Name Description
NOISE_DB
EMISSION
Api Model Operator (AvgOverlay)
API Enumeration description of Operator
Name Description
AVG
AVG_INTERPOLATED
MAX
MIN
Api Model Operator (ComboOverlay)
Name Description
SIN
COS
TAN
ASIN
ACOS
ATAN
SQRT
ROUND
FLOOR
CEIL
ABS
EXP
LN
LOG
RANDOM
ERF
GTE
GT
LTE
LT
NEQ
EQ
IF
AND
OR
SWITCH
ADD
MUL
DIV
SUB
MAX
MIN
AVG
POW
PERCENTILE
AVG_GTE_PERCENTILE
AVG_LTE_PERCENTILE
COLOR
RED
GREEN
BLUE
ALPHA
Api Model Overlay
API Model description of Overlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model OverlayCategory
API Enumeration description of OverlayCategory
Name Description
ADMINISTRATIVE
ENVIRONMENTAL
WATER
GRID_CALCULATION
GEO_DATA
TOPOGRAPHY
NETWORKS
Api Model OverlayType
API Enumeration description of OverlayType
Name Description
OWNERSHIP
OWNERSHIP_GRID
ZIP_CODES
ZONING
NEIGHBORHOODS
MUNICIPALITIES
SCENARIO
VACANCY
HEAT_STRESS
SHADOW
TRAFFIC_DENSITY
TRAFFIC_NO2
TRAFFIC_NOISE
LIVABILITY
AERIUS
RAINFALL
FLOODING
GROUNDWATER
WATERSHED
SUBSIDENCE
WATERWIJZER
AVG
COMBO
DISTANCE
SIGHT_DISTANCE
TRAVEL_DISTANCE
INFERENCE
ITERATION
GEO_TIFF
WMS
WCS
AREA
ATTRIBUTE
FUNCTION
SATELLITE
HEIGHTMAP
UNDERGROUND
SOURCE
NETWORK_OWNERSHIP
NETWORK_OVERVIEW
NETWORK_DISTANCE
RESULT_CHILD
TEST
DISTURBANCE_DISTANCE
SAFETY_DISTANCE
DEPRECATED
Api Model RainOverlay
API Model description of RainOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model Rasterization
API Enumeration description of Rasterization
Name Description
FIRST
MIN
MAX
SINGLE_LAYER
GRID
Api Model RasterizationMethod
API Enumeration description of RasterizationMethod
Name Description
COMBINED
OUTLINE
CENTER
Api Model RasterizationOverlay
API Model description of RasterizationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model RasterizationPrequel
API Enumeration description of RasterizationPrequel
Name Description
INPUT
Api Model ResultChildOverlay
API Model description of ResultChildOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model ResultParentOverlay
API Model description of ResultParentOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model SWRC
API Enumeration description of SWRC
Name Description
NONE
VAN_GENUCHTEN
Api Model SatelliteOverlay
API Model description of SatelliteOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model Scope
API Enumeration description of Scope
Name Description
MAP
WATER_AREAS
LIMIT_AREAS
OVERRIDE_RAIN_AREAS
Api Model ServiceOverlay
API Model description of ServiceOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
sourceID int Source ID
type OverlayType
version int
visible boolean
warnings String
Api Model ShadowAttribute
API Enumeration description of ShadowAttribute
Name Description
DATES
SUN_ALTITUDE
SUN_AZIMUTH
MAX_SHADOW_DISTANCE
MAX_FOLIAGE_RADIUS
Api Model ShadowOverlay
API Model description of ShadowOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model ShadowPrequel
API Enumeration description of ShadowPrequel
Name Description
FOLIAGE_HEIGHT
BUILDING_ELEVATION
TERRAIN_ELEVATION
Api Model ShadowResult
API Enumeration description of ShadowResult
Name Description
SHADE
FOLIAGE
Api Model Shoreline
API Enumeration description of Shoreline
Name Description
NONE
ONE_CELL
TWO_CELLS
Api Model SightDistanceAttribute
API Enumeration description of SightDistanceAttribute
Name Description
SOURCE_HEIGHT_M
OBSERVER_HEIGHT_M
Api Model SourceOverlay
API Model description of SourceOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
restColor TColor
sortIndex int
sources Map<int,int>
type OverlayType
version int
visible boolean
Api Model Style
API Enumeration description of Style
Name Description
INTERPOLATED
NEAREST
ARROW
COLOR
FLOAT32
DIFFERENCE
Api Model SubsidenceAttribute
API Enumeration description of SubsidenceAttribute
Name Description
YEARS
YEARS_PER_TIMEFRAME
START_YEAR
A
B
C
ACTIVE_DRAINAGE_FACTOR
PASSIVE_DRAINAGE_FACTOR
CLIMATE_START_TEMP
CLIMATE_FINAL_TEMP
CLIMATE_START_YEAR
CLIMATE_FINAL_YEAR
CLIMATE_OXIDATION
CLIMATE_SOIL_TEMP_FACTOR
LOW_PASSIVE_DRAINAGE
HI_PASSIVE_DRAINAGE
DEFAULT_PEAT_FRACTION
DEFAULT_TOP_LAYER_THICKNESS
DEFAULT_CLAY_THICKNESS
INUNDATE_LAND_BELOW_WATER_LEVEL
Api Model SubsidenceKey
API Enumeration description of SubsidenceKey
Name Description
WATER_LEVEL
WATER_LEVEL_OUTPUT
CLAY_THICKNESS
INDEXATION
PEAT_FRACTION
TOPLAYER_THICKNESS
SUBSIDENCE
DRAINAGE
HI_GROUND_WATER_LEVEL
LOW_GROUND_WATER_LEVEL
Api Model SubsidenceOverlay
API Model description of SubsidenceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model SubsidencePrequel
API Enumeration description of SubsidencePrequel
Name Description
LOW_GROUND_WATER
HIGH_GROUND_WATER
CLAY_THICKNESS
Api Model SubsidenceResult
API Enumeration description of SubsidenceResult
Name Description
SUBSIDENCE
OXIDATION
SETTLEMENT
LOW_GROUND_WATER
HI_GROUND_WATER
Api Model SurfaceMode
API Enumeration description of SurfaceMode
Name Description
NONE
SHALLOW
AVG_WATERWAY
HYBRID
AVG_TERRAIN
Api Model TrafficAttribute
API Enumeration description of TrafficAttribute
Name Description
HOURS
CARS_ACTIVE
VANS_ACTIVE
TRUCKS_ACTIVE
BUSES_ACTIVE
Api Model TrafficDensityOverlay
API Model description of TrafficDensityOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model TrafficNO2Attribute
API Enumeration description of TrafficNO2Attribute
Name Description
BASE_O3
BASE_NO2
EMISSION_CAR_NOX
EMISSION_CAR_NO2
EMISSION_JAM_CAR_NOX
EMISSION_JAM_CAR_NO2
EMISSION_VAN_NOX
EMISSION_VAN_NO2
EMISSION_JAM_VAN_NOX
EMISSION_JAM_VAN_NO2
EMISSION_TRUCK_NOX
EMISSION_TRUCK_NO2
EMISSION_JAM_TRUCK_NOX
EMISSION_JAM_TRUCK_NO2
EMISSION_BUS_NOX
EMISSION_BUS_NO2
EMISSION_JAM_BUS_NOX
EMISSION_JAM_BUS_NO2
ROAD1_30M_A
ROAD1_30M_B
ROAD1_30M_C
ROAD1_60M_ALPHA
ROAD1_60M_POWER
MIN_TREE_HEIGHT_M
Api Model TrafficNoiseAttribute
API Enumeration description of TrafficNoiseAttribute
Name Description
BACKGROUND_DB
V0_CAR
V0_VAN
V0_TRUCK
V0_BUS
EMISSION_START_CAR
EMISSION_START_VAN
EMISSION_START_TRUCK
EMISSION_START_BUS
EMISSION_MULT_CAR
EMISSION_MULT_VAN
EMISSION_MULT_TRUCK
EMISSION_MULT_BUS
Api Model TrafficOverlay
API Model description of TrafficOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model TravelDistanceAttribute
API Enumeration description of TravelDistanceAttribute
Name Description
MAX_TRAVEL_DISTANCE
ROAD_DISTANCE
ROUTE_PEDESTRIANS
ROUTE_BICYCLES
ROUTE_CARS
ROUTE_TRUCKS
ROUTE_TRAMS
ROUTE_TRAINS
ROUTE_SHIPS
DESTINATION_THRESHOLD
BLOCKING_THRESHOLD
TRAVERSABLE_THRESHOLD
Api Model TravelDistanceKey
API Enumeration description of TravelDistanceKey
Name Description
DESTINATION_AREA
BLOCKED
Api Model TravelDistanceOverlay
API Model description of TravelDistanceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model TravelDistancePrequel
API Enumeration description of TravelDistancePrequel
Name Description
TRAVERSABLE
BLOCKING
DESTINATION
Api Model TravelDistanceResult
API Enumeration description of TravelDistanceResult
Name Description
DESTINATIONS
BASE_TYPES
Api Model WCSOverlay
API Model description of WCSOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WCSResult
API Enumeration description of WCSResult
Name Description
NEAREST
INTERPOLATED
Api Model WMSOverlay
API Model description of WMSOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WMSResult
API Enumeration description of WMSResult
Name Description
COLOR
FLOAT32
RED
GREEN
BLUE
ALPHA
Api Model WWOverlay
API Model description of WWOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model WaterKey
API Enumeration description of WaterKey
Name Description
WATER_LEVEL
WATER_RELATIVE
INLET_Q
INLET_CAPACITY
INLET_AREA
LOWER_THRESHOLD
UPPER_THRESHOLD
UNDERGROUND
INUNDATION_LEVEL
AQUIFER_KD
AQUIFER_DATUM
SEWER_STORAGE
SEWER_PUMP_SPEED
WEIR_HEIGHT
WEIR_WIDTH
WEIR_COEFFICIENT
WEIR_N
WEIR_ANGLE
WEIR_TARGET_LEVEL
CULVERT_DIAMETER
CULVERT_N
CULVERT_THRESHOLD
CULVERT_RECTANGULAR_HEIGHT
PUMP_Q
PUMP_ANGLE
PUMP_AREA
DRAINAGE_Q
DRAINAGE_DATUM
DRAINAGE_OVERFLOW_THRESHOLD
DRAINAGE_ACTIVE
BREACH_SPEED
BREACH_HEIGHT
BREACH_WIDTH
BREACH_ANGLE
BREACH_COEFFICIENT
BREACH_INPUT_AREA
BREACH_LEVEL_AREA
EXTERNAL_SURFACE_LEVEL
EXTERNAL_WATER_LEVEL
EXTERNAL_AREA
SEWER_OVERFLOW
SEWER_OVERFLOW_SPEED
OBJECT_FLOW_OUTPUT
OBJECT_DATUM_OUTPUT_A
OBJECT_DATUM_OUTPUT_B
OBJECT_WIDTH_OUTPUT
OBJECT_HEIGHT_OUTPUT
OBJECT_WATER_AREA_OUTPUT
WEIR_DAM_OUTPUT
TRACER_A
TRACER_B
TRACER_C
TRACER_D
LIMIT_AREA
RAIN_M
Api Model WaterModelAttribute
API Enumeration description of WaterModelAttribute
Name Description
ALLOWED_WATER_INCREASE_M
GROUND_WATERTABLE_WITH_SURFACE
DESIGN_FLOOD_ELEVATION_M
GROUND_BOTTOM_DISTANCE_M
GROUND_BOTTOM_PRESSURE_M
GROUND_WATER
GROUND_WATER_DEPTH_M
HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS
SOIL_WATER_RETENTION_CURVE
UNSATURATED_FRACTION
IMPACT_FLOOD_THRESHOLD_M
IMPACT_RANGE_M
CULVERT_DEM_THRESHOLD_M
QCELL
INCREASED_RESOLUTION
SHORELINE
OBJECT_ENTRY_CORRECTION
SEWER_OVERFLOW_THRESHOLD
DURATION_MIN_LEVEL_M
RISE_RATE_DISTANCE_M
SURFACE_WATER_EVAPORATION_FACTOR
TIMEFRAMES
TIMEFRAME_TIMES
LIMIT_AREA
LIMIT_RAIN
MAX_WATER_BOTTOM_M
START_DATE_MS
AVG_SHORE_WIDTH_M
AVG_TERRAIN_WIDTH_M
AVG_TERRAIN_STORAGE_M
SURFACE_WATER
PREQUEL_SURFACE_LEVEL_RELATIVE
MICRORELIEF_STORAGE_FRACTION
MIN_MAX_ELEVATION
BRIDGE_ELEVATION
MAX_INFILTRATION_M
MIN_DRAIN_SURFACE_DISTANCE_M
INFILTRATION_FACTOR_S
WEIR_DAM_MULTIPLIER
WEIR_DAM_SURPLUS_HEIGHT_M
BREACH_MEASUREMENT_DISTANCE_M
STABILIZER_ANGLE
WEIR_MOVE_INTERVAL_S
WEIR_MOVE_STEP_M
WEIR_MOVE_RANGE_M
PARTIAL_START_SEC
PARTIAL_END_SEC
TRIM_MANNING
TRIM_EVAPOTRANSPIRATION
TRIM_ROOT_DEPTH
TRIM_GROUND_INFILTRATION
TRIM_GROUND_CONDUCTIVITY
TRIM_SHORELINE_CONDUCTIVITY
TRIM_GROUND_STORAGE_FRACTION
Api Model WaterOverlay
API Model description of WaterOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WaterPrequel
API Enumeration description of WaterPrequel
Name Description
TERRAIN_ELEVATION
SURFACE_LEVEL
SURFACE_U
SURFACE_V
SURFACE_INFILTRATION
GROUND_WATER_DEPTH
GROUND_WATER_DATUM
GROUND_CONDUCTIVITY
GROUND_INFILTRATION
BOTTOM_DISTANCE
BOTTOM_RESISTANCE
BOTTOM_PRESSURE
MAX_INFILTRATION
MANNING
MICRORELIEF
SEWER_LEVEL
Api Model WaterResult
API Enumeration description of WaterResult
Name Description
WATER_STRESS
SURFACE_LAST_DIRECTION
SURFACE_AVG_DIRECTION
SURFACE_DURATION
SURFACE_ELEVATION
SURFACE_FLOW
SURFACE_LAST_FLOW
SURFACE_LAST_SPEED
SURFACE_LAST_VALUE
SURFACE_LAST_DATUM
SURFACE_MAX_SPEED
SURFACE_MAX_VALUE
SURFACE_EVAPORATION
SURFACE_LAST_EVAPORATION
BUILDING_LAST_STORAGE
FLOOD_ARRIVAL_TIME
FLOOD_RISE_RATE
LAST_RAIN
RAIN
GROUND_LAST_STORAGE
GROUND_LAST_VALUE
GROUND_LAST_DIRECTION
GROUND_FLOW
GROUND_MAX_STORAGE
GROUND_MAX_VALUE
GROUND_WATERTABLE
GROUND_BOTTOM_FLOW
GROUND_LAST_UNSATURATED_STORAGE
GROUND_LAST_UNSATURATED_FRACTION
GROUND_TRANSPIRATION
GROUND_LAST_TRANSPIRATION
SEWER_LAST_VALUE
SEWER_MAX_VALUE
LAST_EVAPORATED
LAST_EVAPOTRANSPIRATION
EVAPORATED
EVAPOTRANSPIRATION
IMPACTED_BUILDINGS
TRACER_A
TRACER_B
TRACER_C
TRACER_D
BASE_TYPES
SURFACE_DIFFERENCE
DEBUG_UV
GPU_OVERVIEW
DEBUG_AVG_AREAS
DEBUG_UV_DIRECTION
DEBUG_WATERWAYS
SURFACE_LAST_U
SURFACE_LAST_V
Api Model WaterSystem
API Enumeration description of WaterSystem
Name Description
OBJECTS
AREAS
Api Model WatershedKey
API Enumeration description of WatershedKey
Name Description
DISCHARGE_AREA
Api Model WatershedModelAttribute
API Enumeration description of WatershedModelAttribute
Name Description
FILL_DISTANCE
DISCHARGE_REMAINING_WATER
CULVERT_FLOW_DIRECTION
MIN_AREA
LIMIT_ROAD
Api Model WatershedOverlay
API Model description of WatershedOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
method DischargeMethod
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WatershedPrequel
API Enumeration description of WatershedPrequel
Name Description
DIRECTION
Api Model WatershedResult
API Enumeration description of WatershedResult
Name Description
WATERSHEDS
DISCHARGE_AREAS
DIRECTION
BASE_TYPES
Api Model ZoneDistanceAttribute
API Enumeration description of ZoneDistanceAttribute
Name Description
HIT_COUNT
