Api session event editor weather set trigger sec
Revision as of 13:42, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorweather/set_trigger_sec.
Description: Set whether the specified Weather's visualization Trigger automatically.
0 REQUIRED (WEATHER Integer ID) Weather ID
1 REQUIRED (Floating point number) Auto-Trigger (false means the Weather's visualization does not Trigger automatically)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 19 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 93 ]'
JavaScript example POST:
 body: '[ 1, 19 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/", options)
