Api session event editor specialeffect duplicate
API Endpoint: editorspecialeffect/duplicate.
Description: Duplicate existing Special Effect
| 0 | REQUIRED | (SPECIAL_EFFECT Integer ID or multiple values in array [1, 2, 3]) | Special Effect |
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/duplicate/", options)
