Api session event editor specialeffect add
API Endpoint: editorspecialeffect/add.
Description: Add new Special Effect
| 0 | OPTIONAL | (Point with crs: EPSG:3857) | Location (optional) | |
| 1 | OPTIONAL | (PARTICLE_EMITTER Integer ID) | Particle Emitter (optional) |
| 200 | Integer (Special Effect ID) |
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "", "" ]'JavaScript example POST:
body: '[ "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/add/?crs=3857", options)
