Api session event editor setting set wind speed
Revision as of 13:40, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsetting/set_wind_speed.
Description: Set Wind Speed
0 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '49'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '9'
JavaScript example POST:
 body: '49'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/", options)
