Api session event editor setting set limit map
Revision as of 13:40, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsetting/set_limit_map.
Description: Set Project Map Limit Area
0 REQUIRED (MultiPolygon with crs: EPSG:3857) Limit Polygon
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_limit_map/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
JavaScript example POST:
 body: '{ "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_limit_map/?crs=3857", options)
