Api session event editor setting remove crs
API Endpoint: editorsetting/remove_crs.
Description: Remove Crs
| 0 | REQUIRED | (String) | String |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/remove_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'JavaScript example POST:
body: '"Text"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/remove_crs/", options)
