Api session event editor scenario remove event
Revision as of 13:39, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorscenario/remove_event.
Description: Remove Event
0 REQUIRED (SCENARIO Integer ID) Scenario
1 REQUIRED (Integer number) Integer
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/remove_event/", options)
