Api session event editor parametric add
API Endpoint: editorparametric/add.
Description: Add new Parametric
| 0 | REQUIRED | (Enumeration) | Alignment | ROAD or SPACED |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorparametric/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ROAD"'JavaScript example POST:
body: '"ROAD"'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add/", options)
