Api session event editor panel set template apply automatically
Revision as of 13:39, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/set_template_apply_automatically.
Description: Set Template Apply Automatically
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Template Panel
1 REQUIRED (true, false) Apply automatically at start of session true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_apply_automatically/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_apply_automatically/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], true ]'
JavaScript example POST:
 body: '[ 1, false ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_apply_automatically/", options)
